How to attach hole call out to cosmetic thread?
Hi all,
I am trying to use custom hole chart in Creo 7.
Everything is OK except that the call out of standard holes are not attached to the cosmetic threads.
Fig.1
According to our company standard, it should look as in Fig.2
(the arrow always points toward the center, and it is attached to the thread)
Is there any way to achieve this?
Fig.2
If you have any ideas, please let me know. Thank you so much!
tbraxton
I have not tested this on a cosmetic thread surface but it may work,
Try this in the part model
1) open the note's properties in the model
2) unplace the note
3) place the note, selecting normal leader option, and attaching the note to one of the two half-cylinder surfaces
Hidetaka1-VisitorAuthor
Thank you for your answer.
It is possible to edit attachment every time, but it is very inconvenient.
Actually I am looking for kind of an "automatic" solution, like a config option or drawing option, or a change in .hol file.
It seems that others have the same problem and PTC does not really care...
tbraxton
Two options come to mind to avoid manually updating the leader for each hole. Both are similar in approach.
Use the copy/paste functionality to paste a "correct" version of the hole with note. This would require the creation of a reference model with the note per your spec. You would then retrieve that model to get the hole into a given model.
You could also try using a UDF for your hole(s) where you have modified the leader attachment to your specification. You can then place the hole using UDF functionality and the note should be as defined in the UDF.
TomU
Unfortunately this is how Creo (Pro/e) has worked forever and (so far), no one at PTC has been willing/able to change it.  There are a couple of open product ideas about that exact issue.  Go vote them up!
Thank you!
I upvoted both of them.
Hope that PTC does something about this soon.
kdirth
Try this:
  • Select note on drawing
  • RMB
  • Select Change Note Type then Normal Leader
  • Select Cosmetic Thread
  • MMB to place
  • Move note to desired location
  • Drag arrow approximately to normal position and it will snap to normal
I am sorry I was not clear enough in my question.
Actually I am looking for a way to do it automatically, so that I don't need to edit the attachment every time.
Still no hope though...
kdirth
I could not find a setting that affects the default note style for hole tables.  It would be nice if they would add that to the detail options.
The only way I know of to speed this up would be to create a mapkey.
