Oct 30, 2014 9:11 AM UTC
how to change color of a part using relation?
Is there some posibility to chnge color of a created part using a relation in start_part_solid.prt?
for example - if the PTC_COMMON_NAME_IS screw, then color of the part should be for ex. red....
Thanks in advance
T.
KenFarley
Oct 30, 2014 11:06 AM UTC
No, it's not possible. I don't know if it will ever be possible, even though it would be very useful. For example, if you use springs from a particular supplier, they tend to be color coded based on their type. It would be great to have them reflect that in the model when you use a specific one from a family table.
Oh, well.
thlavinka1-VisitorAuthor
Oct 30, 2014 11:14 AM UTC
so lets belive one day it will be possible
Nov 4, 2014 10:35 PM UTC
I suppose you can use a offset feature of zero value to do that.
I tried and found out that it´s easier to do with offset from Flexible Modeling.
See if my video helps.
Jose
Video Link : 5426
Nov 5, 2014 12:36 AM UTC
Okay, I tried next step, changing in relations and I think it can be done:
Video Link : 5427
For this you need Pro/program and Relations.
For my example, I did it like this:
1. Created 3 parameters Yes/No type:
BLUE_RESUME
YELLOW_RESUME
GREEN_RESUME
And a Integer parameter:
COLOR
2.Created the following relations:
COLOR=0
BLUE_RESUME=NO
GREEN_RESUME=NO
YELLOW_RESUME=NO
IF COLOR==1
BLUE_RESUME=YES
GREEN_RESUME=NO
YELLOW_RESUME=NO
ENDIF
IF COLOR==2
BLUE_RESUME=NO
GREEN_RESUME=YES
YELLOW_RESUME=NO
ENDIF
IF COLOR==3
BLUE_RESUME=NO
GREEN_RESUME=NO
YELLOW_RESUME=YES
ENDIF
3. Enter the Program, search for the feature "BLUE" and change to:
IF BLUE_RESUME==YES
ADD FEATURE
INTERNAL FEATURE ID 1849
END ADD
END IF
Repeat for Yellow and Green.
It is also possible to use a family table, a much more simpler solution.
Jose
Nov 7, 2014 5:27 AM UTC
Great!
And is it possible to add a rule for ex.: if model_name=XXX then the color will be COLOR_1?
2-Explorer
Nov 7, 2014 10:52 AM UTC
It will need some system in model naming.
Example:
Model name: part_01-red
Relation:
part_name=EXTRACT(REL_MODEL_NAME,1,SEARCH(EXTRACT(REL_MODEL_NAME,1,(\STRING_LENGTH(REL_MODEL_NAME))),"-")-1)
part_color=EXTRACT(REL_MODEL_NAME,(SEARCH(REL_MODEL_NAME,"-")+1),((\STRING_LENGTH(REL_MODEL_NAME))-(SEARCH(REL_MODEL_NAME,"-")+1)+1))
IMPORTANT: Use only 1 "-" in model name. This mark will divide part name into 2 parts.
Before "-" it´s parameter called part_name.
After "-" it´s parameter called part_color.
Relation:
IF part_color == red
ENDIF
Patriot_1776
Nov 7, 2014 2:54 PM UTC
Why would you want to do this? You can assign appearances to materials, and then specify the material. Then you also get material properties.
Nov 7, 2014 3:21 PM UTC
That would mean that the user would need to update the material everytime!!! LOL
Patriot_1776
Nov 10, 2014 3:12 PM UTC
So? You'd get proper material properties. As antonius mentioned, the appearance is a little buggy when using fam tables, but I think a second regen fixes that if I remember.
If you want to be lazy, you could simply wrote a relation to change the material. I.E. if TITLE1 == "SCREW" THEN ptc_material_name = steel
Not sure the syntax is 100% but you get the picture.
2-Explorer
Nov 9, 2014 2:40 PM UTC
Mainly keep it simply!!!
Just some ideas:
What about BULK items? See ProE help for more informations...
What about restricted parameters? And restricted parameters tables? See ProE help...
How many different parts do you wanna create? Is it 10 or 100 000? Has it any sence to make so "coplicated" method?
Nov 10, 2014 8:04 AM UTC
I havent heard about bulk items yet - thanks for a suggestion.
I created one BULK item with two instances in family table. Now i would need to make following relations in assembly template:
- in case the assembly contains a part or subassembly with model name starting "JD_" then i need to assign a parameter "BARVA" (value RAL_5018) from the BULK into a table in asm drawing.
in case the assembly contains part or subassembly with model name starting "MF_" then i need to assign a parameter "BARVA" (value RAL_1012) from the BULK into a table in asm drawing.
2-Explorer
Nov 10, 2014 8:11 AM UTC
All necessary information are here in this topic. Try it in your own...
