How to change dimension of complete object (Creo 3.0 personal)
  • March 13, 2012
  • 2 replies
  • 3970 views
I am a newby in Creo Elements/Direct. A supplier gave me an STEP-file (attached) which I want 3D-printed 87 times smaller than the files is.
I first started with the 'scale'option, but then the dimensions stay the same.
I think I am missing something.
Arnold
Did you put in the scale-factor 0.0114942 ?
Normally the scale-factor is limited, so the scale 1/87 does not work.
Then write into the input line this:
(K2-UI::sd-set-min-scale-value .01)
Press enter and try again.
Best wishes !
Matthias
Thanks for your answer. This scalefactor is accepted (1:87 or 1/87 was not).
