how to change language for drawing notes to rusian?
  • March 12, 2016
  • 1096 views
Hello ,
i need to be able to change teh drawing notes language between latin and cyrilic letters .
Which property i have to change , to be able to use both ?
if you need to type a note containing russian letters, then you have to use proper font. If you add the following option into config.pro file, then you can set any Windows TrueType font for your note.
PRO_FONT_DIR  C:\Windows\Fonts
MH
