Sep 2, 2014 3:53 PM UTC
How to change number of digits in repeat region
I need your help with active_draving.dtl file setting-up so that i would have one more digit (4gigits) in a red colored column in the drawing
as below. It is just a family table with a parameter "MASS" - I cannot find the right option in dtl file to make the number more accurate.
Thanx a lot in advance
Tom
Sep 2, 2014 5:38 PM UTC
Just guessing as I don't use repeat regions... can you use the [.4] at the end of the variable in the table?
Sep 2, 2014 6:10 PM UTC
Do you mean the table in drawing, family table in part or the variable in relations?
here some printscreens:
Sep 2, 2014 6:24 PM UTC
[.4] after a numeric parameter overwrites the default number of digits to 4.
Apr 20, 2016 7:35 PM UTC
in drawing under layout--format--decimal places, fill the number of digits you want, then select the one or group by crossing over you want to change, done. Bill
Jul 27, 2022 1:47 PM UTC
In using Creo 8, "drawing under layout--format--decimal places,", this works for me.
fam.inst.param.name{.number of digits]  didn't work for me. (In past versions, this was the fix).  Still works for Mass properties though.
I noticed that having the dimensions displayed as "@S" prevents the digits from being displayed in the table.
You have to change them back to "@D" temporarily, and the number of digits display will update (with update tables).
