How to change the circular line and arc resolution in creo parametric 3.0
It is faceted badly. Is it due to metric format?
    try following config.pro Settings:
    edge_display_quality very_high
    shade_quality 15
    enable_fsaa 16
    but be carefull... file size will increase. maybe you have to play with the values to find out the right settings for you.
    jzamora1-VisitorAuthor
    Seems to be working great, Thanks!
