how to check that in an assembly a *_sk* component is a skeleton and not a part ?
  • April 7, 2017
  • 3 replies
  • 1665 views
We want to ensure that skeleton is used in assembly, and not part renamed as a skeleton
Hi Jean
They do not have the same icon, parts and skeletons
Skeletons are always the first you have in your model tree, befor yuor datums
ES
jconedera1-VisitorAuthor
Fully agree, but is there a way to check that automatically ? using Modelcheck for exemple
Well, that is a good question
I am not a Modelcheck guy, but I guess you have some copy geom from your skeleton, if yes you should be able to check if they comes from a skeleton or not.
Modelcheck has a lot of limitations, so you may need a Protoolkit program to do it
