How to combine multiple viewables per command line
  • December 9, 2016
  • 1298 views
Hi all,
I can create a viewable of multiple different viewables (MCAD and ECAD) by simply dragging them at the same time on the Creo View window. Then after saving the PVZ, I can open it again and all viewables are in there.
What I am trying to accomplish is to do this, but with a batch process.
Sadly I didnt'd find a solution with the proposed pvsmake when trying
pvsmake.exe -DrC:\ptc\creo_view_adapters\step_setup\pvsmake.rcp -o %model_base%.pvs %model1%.pvs %model2%.pvs %ecad-model3%.pvs
Even if it creates a file, it cannot be opened in Creo View. What am I doing wrong?
Another question would be how to make a PVZ of the resulting PVS file per command line?
greetings
SvenR14-AlexandriteAuthor
Well, the first thing I solved after reading again the documentation - I used a parameters incorrectly. It works like this:
pvsmake.exe -rC:\ptc\creo_view_adapters\step_setup\pvsmake.rcp -ocombined.pvs %mcad_step_base%.pvs %schem_base%.pvs %pcb_ipc2581%.pvs
But I still wonder how to convert to PVZ via command line... it should be easy, I think I am missing something there...
greetings
