l have an issue in regards to exporting the PDF as the drawing line are thicker. How can l solve this as shown by drawing below ?
StephenW
The video shows you how to set up a pen table file. If the line weights aren't correct, adjust the values in the pen table file until they work for you.
2-Explorer
i have an issue where my pdf for my D size looks great, but B size is thicker lines.
Hi, try to check if the system loads the correct pentable file for both exports
