How to connect the two surfaces smoothly
- 3 replies
- 2668 views
- Translate All
I use the style command to draw two curves(as picture 1 shows), and then use the boundary blend command to generate the surfaces, but when finish this, I can't complete the thicken command, and how two the generated surface to connect smoothly with the two neighbouring surfaces.I use wildfire 4.0.
Can someone help me?Thanks in advance.
