How to create annotation sets in *.ASM with Creo View?
Hello forum,
I got an assembly here in the form of one *.asm and several *.prt files in one folder.
I can view the assembly in Creo View. However, it seems that I cannot modify or create annotation sets. Also, it does not seem to be possible to export the assembly as *.PVZ from Creo View (to then create annotation sets in the PVZ file).
Or is there any other way to create and save annotation sets here?
Chris3
Chris3Answer
ok in that case I think your problem is that you are opening the native CAD and Creo View doesn't support saving annotations to the native CAD:
https://www.ptc.com/en/support/article/CS93630
Can you open it in Creo Parametric and save it as a pvz?
Chris3
Sounds like you are using the Creo View Lite version? I don't know what annotation sets you are trying to modify but it could be possible you need a MCAD license:
Creo View version comparisons:
https://www.ptc.com/-/media/Files/PDFs/CAD/Feature-Comparison-of-PTC-Creo-View-MCAD-Product-Suite_DS.pdf
VeqTor1-VisitorAuthor
No I'm using Creo View MCAD -- which perfectly allows to create (and save!) annotations -- however only on PVZ files and (seemingly) not on *.asm files.
Chris3
Chris321-Topaz IAnswer
