How to create Dimension with Common reference in Creo 6
Hello
How we could create dimension using common reference in Creo 6 ( in the attached figure it shows for Creo 2)
kdirth
kdirthAnswer
In Creo 4.0 and probably the same in 6.0, select the base reference, then, holding control key, select all other references before placing dimensions.
Mahesh_Sharma
22-Sapphire I
September 2, 2019
@MohaSharifi
Dimension - Common references is o more available as it was merged in Dimension from Creo 3.0. You need to use CTRL for such dimensions.
kdirth
kdirth21-Topaz IAnswer
Thanks, yes it needs to select other references while holding the control key before finishing dimensions placement.
