How to created the family table in assembly drawing
Hi all,
there's an question distracting me.
Suppose we have a cube, and it divided into two part, top & bottom,
I can create the family table and setting the parameter(dimension) in the parts drawing,
but when I follow the same step to create the family table in assembly drawing,
I found out that "I can't select the part drawing's dimension as the parameter" in the assembly drawing,
what I want to do is to change the dimension(length*width) in family table directly, then we got the different outline dimensions in each instance,
I'm sure it's pretty easy to you guys. I'd welcome some advice.
Simon
