6-Contributor
How to delete a feauture using ProProgram/Relation
Is it possible to delete feature with the help of relations/Proprogram.
The requirement is that, I have a master model, from which i can generate two designs by suppressing and un supressing some features.
And when i generate a particular model from the master model, i need to automatically delete the suppressed feature, as its not longer needed for that part.
Sajith
Chris3
You can suppress the feature, yes.
Check out this thread:
https://community.ptc.com/t5/3D-Part-Assembly-Design/Pro-Program-IF-statement-question/td-p/675380
6-Contributor
Hi @Chris3,
Thanks for sharing the link.
But i feel the discussion talks about suppressing a feature and not deleting.
Please correct me if 'm wrong.
I am actually trying to delete a feature( suppressed or un supressed)
Sajith
ProProgram/Relation does not enable you to delete feature.
6-Contributor
Thanks @MartinHanak
