how to design a pressure vessel...?
how to design a pressure vessel according to asme code...?
Dale_Rosema
This is a fairly vague question.
What are your intents? Having parameters in the model based on the section of code I, IV, VIII, PP? Driving the design based on those parameters?
Are you looking to do stress calculations beyond the ASME Code calculations?
Do you have up to date copies of the ASME code?
There is a lot that goes into designing a code vessel.
Dale_Rosema
the first one ..
how to have parameters in mode,l based on bpvc codes..
Can you please elaborate the requirement.
What exactly you want to do, do you want to create 3D model and drawing as per ASME code in Pro/E.
//BR
Manoj
okay.
is there is any tab though which I can prepare 3d model of pressure vessel.
