how to display the value of a drawing property in a note
I want to call out in a note in the drawing automatically the value of the drawing property "projection_type".
How can I do this?
I tried with "&projection_type" but was not successful.
Thx,
Peter
You can use the following syntax to display drawing parameters in notes:
&parameter:d
Here's a link to the PTC documentation.
Ty
Hello there,
Sorry but what you suggested doesn’t function.
I tried:
&parameter:projection_type
And
&projection_type:d
But none reflected my drawing property as first_angle as it is in the drawing properties.
So the solution seems not valid for me.
it could be that the syntax is still unclear to me but i cannot make more out of the documentation.
Best regards,
Peter Arras
Program director Master EM
KU Leuven – Faculty of Engineering Technology
Campus De Nayer
J.P. De Nayerlaan 5
BE2860 Sint Katelijne Waver
KenFarley
I think there was a misunderstanding of what you were asking.
The projection_type setting is an option of the drawing, not one the general user sets (I've not ever done so), so it was assumed you were referring to a drawing parameter. The parameters are things you set yourself within the drawing, much like part parameters, which can be integer, real, string, or yes/no values.
To show a parameter in a note you do as previously suggested.
To use creo options in notes is not something I know how to do. I'm not sure it can be done. I don't think that kind of data can be accessed in that manner.
