How to edit the name of the folders and profiles in Creo Advanced Framework Extension (AFX)
referring the article CS392162, I'm not able to edit the name of the folders.
In my example I need to add the mechanica beams and I want to maintain the original ones.
I already create the folder structure, as you can see in the image attached:
- simulate
    - steel_beams_mm_mechanica
    - steel_beams_inch_mechanica
I want to change the label of the folders:
- SIMULATE
    - MECHANICA MM
    - MECHANICA INCH
I need it in two different languages, english and another one.
Thanks in advance
SamuelBrantner
Hi @Armando_Pirlo ,
how did you modify your afx_custom.txt text file?
Maybe this will also help you to understand how the customization needs to be done:
https://youtu.be/-iLYU-YT8e4?si=L-5LDfymiBw5naD5&t=434
Greetings Sam
SamuelBrantner
Hi @Armando_Pirlo ,
Greetings Sam
Hi Samuel,
thanks for the link.
I solved with your indications.
My error was the customization_path option definition.
