How to export a assembly file to step file with section view
As the title,how to export a asm. file to step file with section view?
because use extrude to cut the view in assembly file needs take a long time to calculate,
if use section view will be convenient.
StephenW
StephenWAnswer
Creo exports the cross section as a section that step understands as a cross section.
This is not the same as a cut that actually removes material.
I understand that an extruded cut takes a lot of time but a cross section will not do what you want it to do.
Is the section concept even supported by the STEP file format itself?
Yes, it is. cause I don't want coporating vendor see the 3D outline.
Do you have any solution could provide? or creo actually can't do this at all?
You right about STEP supporting cross section indeed.
When searching the Help Center, you will find this section: http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/data_exchange/interface/Importing_Exporting_Cross_Sections.html
