May 29, 2013 8:11 PM UTC
How to export Modelcheck's model dimensions in a parameter
HI,
We know it is possible to calculate and report the dimensions of a model (boundary box) with Modelcheck.
But I would like export the resulte in a parameter of the model.
Do you know for do that ?
ps: sorry for my bad english !
TomU
May 29, 2013 8:38 PM UTC
See document CS29792 in the knowledge base.
Use ModelCHECK to add a string parameter SIZE.
  1. Set ModelCHECK configuration Check files (*.mch) option OVERALL_SIZE to Y for respective ModelCHECK mode
  2. Set ModelCHECK configuration Check files (*.mch) option ADD_CHK_PARAM to Y for respective ModelCHECK mode
  3. Set ModelCHECK configuration Start files (*.mcs) option PRT_ADD_CHK_PARAM, <Parameter_Name> = OVERALL_SIZE for respective ModelCHECK mode
bliboutet1-VisitorAuthor
May 30, 2013 6:25 AM UTC
