Aug 7, 2013 9:09 AM UTC
How to export the content of a "project"
I have projects which contains directories which in turn contains master data. On a right click on the project or one of its directory, there is no "export" action. The only way I found is to export one by one the master data.
Is there any means to export the content of a project or one of its directories?
Aug 7, 2013 1:21 PM UTC
What do you mean by "directories"? Packets?
If your masterdata are controlled by your project, they should share the same Project Id. Then you may search masterdata against this Project Id. The result may show several masterdata. Then [Ctrl][A] and export.
Is that useful?
Aug 7, 2013 2:08 PM UTC
See attachment. I would like, for example, exoprt all the master data under 41029/10/71.
Aug 7, 2013 2:59 PM UTC
Ok; I see. Without any customization, it could be achieved with more than just one click, but probably with less clicks than masterdata in project (I hope so). I suggest the following steps:
1: from the image you attached, select all elements belonging to the folder 71 (with the masterdata and folders children)
or alternatively
1a: open your 41029/10/71 folder [DB Properties], [Structure]
1b: expand this folder [+], and its children folders; not [Expand All]. You should see all your desired masterdata mixed up with your folders
2: send all this collection [Ctrl][A] to a table [Table Edit]
3: in the Table Editor, add the "Class Type" attribute [Layout], [Masterdata], [Class type], and sort on it. Then all your masterdata are grouped together
4: select all your masterdata [click], [Shift][click] and then you may [Export] this collection to a selected folder
This function could be customized, through java API, adding a custom action to the osmProjFolder class name if needed.
