8-Gravel
May 28, 2014
How to express the conic round in engineering drawing?
  • May 28, 2014
  • 2 replies
  • 3552 views
Hi everyone,
I creat a conic round,the conic parameter as following picture:
my question is how to express these parameters of this feature in engineering drawing?
By the way, what's the definition of the round sharpness?
thanks.
Patriot_1776
Sharpness? I think you mean the rho value.
zhenqiang8-GravelAuthor
8-Gravel
May 29, 2014
it's rho exactly.
See the following Help page.
http://www3.eng.cam.ac.uk/DesignOffice/cad/proewild3/usascii/proe/sketcher/example_conic_rho_dimension.htm
Example: The rho Dimension of a Conic
The rho dimension of a conic segment PQ defines the shape of the conic. The line segments PR and QR are tangent to the ellipse at points P and Q respectively. The line segment RD intersects the line segment PQ at point D. Here, D is the mid point of the line segment PQ. The rho dimension specifies a ratio along a vector from the chord (PQ) through a point C to the vertex (R). Point C is at the maximum distance (CD), measured by a normal from the chord PQ to the conic segment PQ.
  1. rho = a/(a+b)
Martin Hanak
Patriot_1776
