Apr 21, 2017 11:42 AM UTC
how to get dimension values
     anybody please help me to get dimension name and its values for a given creo part using jlink coding.
send any idea about that dimension name and values.
Apr 21, 2017 1:58 PM UTC
I don't use jlink but here is an excerpt from the user manual -
Dimension Objects
Dimension objects include standard PTC Creo Parametric dimensions as well as reference dimensions. Dimension objects enable you to access dimension tolerances and enable you to set the value for the dimension. Reference dimensions allow neither of these actions.
Getting Dimensions
Dimensions and reference dimensions are PTC Creo Parametric model items. See the section Getting ModelItem Objects on page 208 for methods that can return Dimension and RefDimension objects.
Dimension Information
Methods Introduced:
• pfcModelItem.BaseParameter.GetValue
• pfcModelItem.BaseParameter.SetValue
• pfcModelItem.BaseDimension.GetDimValue
• pfcModelItem.BaseDimension.SetDimValue
• pfcModelItem.BaseParameter.GetIsDesignated
• pfcModelItem.BaseParameter.SetIsDesignated
• pfcModelItem.BaseParameter.GetIsModified
• pfcModelItem.BaseParameter.ResetFromBackup
• pfcModelItem.BaseParameter.GetIsRelationDriven
• pfcDimension.BaseDimension.GetDimType
• pfcDimension.BaseDimension.GetSymbol
• pfcDimension.BaseDimension.GetTexts
• pfcDimension.BaseDimension.SetTexts
All the BaseParameter methods are accessible to Dimensions as well as Parameters. See the section Parameter Objects on page 257 for brief descriptions.
Note
You cannot set the value or designation status of reference dimension objects.
Apologies for copy/paste formatting
Apr 22, 2017 6:34 AM UTC
thank you ..so much
