2-Explorer
Mar 13, 2014 3:08 PM UTC
How to get intersection witness lines on driven dimensions?
I am unable to enable intersection witness lines for driven dimensions in the model. It is grayed out in the dimension properties dialog. They work perfectly if I create a non-driven dimension directly in the drawing. If I create a feature in the model with a sharp corner and later add a fillet, then I cannot use the driven dimenison and get intersection witness lines. Is there are way to do this?
Thank you.
Mar 13, 2014 6:44 PM UTC
funny, we just got a group email about doing this.
enable intersection witness lines:
Open Drawing Properties options.
File>Prepare>Drawing Properties>Detail Options>Change
Find "witness_line_intersection", default is "no", use Add/Change to set it to "yes".
note: it only applies to new dimension
2-Explorer
Mar 13, 2014 6:49 PM UTC
Thank you.
I'm aware of this option. The problem I'm having is applying them to 'driven dimensions'--those that appear when you click "Show Model Annotations". It works perfectly if I create a dimension directly using the Annotate tab in drawing mode.
Mar 13, 2014 6:54 PM UTC
ahh, sorry, i hadn't actually had a use or tried it yet.
