How to hide sweep profile in drawings
I have a helical sweep and a swept blend that show up in my drawings regardless of what layers I hide. Is there a trick to hiding these so they don't show up in the "no hidden" view?
Thanks!
nhanrattyAnswer
Emery
We suffered a similar issue not so long ago.
Try setting the config.pro option 'mesh_spline_surf' set to no.
Good luck
Neal
Did you try hiding the feature in the model?
efrey1-VisitorAuthor
I need the feature to be present in other views on the sheet.
You can layer the feature in the model and selectively hide the layer per view in the drawing.
2-Explorer
May 14, 2015
Have you tried creating a rule based layer that grabs all curves? You could then hide that layer. Not sure if they are cosmetics or other, but if you can gather them on a layer you can hide them. Here is a sample layer that collects curves.
If you pick the edit rules you can create rules to grab the desired entities.
I did a video on these in a previous life:
Using Rules to control layers in Creo and Pro/ENGINEER - EAC Tip of the Week - YouTube
nhanratty1-VisitorAnswer
Emery
Good luck
Neal
WHOO HOOO!
Thanks for all the replies, changing the config setting did the trick. I would have never have found that one! Below is the image with the fix implemented for reference;
