I am having Creo 4.0 M030... No, I am not looking for drawing origin through code of toolkit... I am concerned about how to check origin of drawing? What is meant by most of drawing have lower left corner as origin.. ? I thought only lower left is origin.. but I was looking for origin coordinates... Does it be other than zero,zero for lower left corner?
My concern is that our toolkit code works fine for dimension placement for one template specifically.. if I just change template to default one of creo, everything is misplaced by code... So, can origin be negative point? How to verify the same...? Is there something which makes template different for same size of templates ?
Is there a different way to define origin of a drawing ? Can we have non zero coordinates for origin of drawing template?
Is there a way to identify the coordinates of starting point and can it be somewhere else rather than lower left corner? Or it's not at all in users choice but it is predefined only by Creo ?
Windchill Satisfaction Survey
Help shape the future of Windchill. Take our 5-minute survey and share your feedback.
