How to import creo file (.prt) in solid works with minimum data loss
I need to import .prt file in solid works with minimum data loss and in editable format. Also with feature recognition as accurate as posiible.
I tried importing one .prt file in solid works but data and feature recognition is not properly extracted.
Please help me with this
Kotom-EngAnswer
You are in the wrong forum.
PTC has two CAD systems:    Creo Parametric    and     Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
Kotom-Eng16-PearlAnswer
StephenW
Feature recognition is a solidworks feature, not a creo feature. You need to ask this question in a solidworks environment to get more helpful answers.
