how to keep screen orientation fixed when switching cross sections or simplified reps
Hi - How can I keep a part or assembly orientation fixed on the screen when switching between cross sections and/or simplified reps?
The model jumps around randomly every time I switch, requiring time and effort just to get back what I wanted to look at. Slows things waaaaay down in my head.
I tried a few years ago to find a solution, but couldn't find any online, or even any references to the issue. Either I'm the only person who experiences this or I'm the only one who finds it to be a problem. Both are hard to believe!
Thanks for any help or insight.
(btw I'm using Creo 3 M110)
dcokinAnswer
No, you're not the only one.  Issues related to this are my biggest gripe with Creo.  It's a much deeper problem than you even state.  If you think you've saved a view / orientation (camera position, direction, focal length), you haven't really.  It will scale parametrically with the overall model's bounding box, even if you don't want it to, no way to stop it.  (Yes, even focal length will change when saving a perspective view, although they use the term "focal length" within the software to mean something else.)  This drives me crazy, since I make so many design changes and want to make powerpoint slides where you flip between pages and see exactly what changed since yesterday; ought to just take a sec, but since the scale of the view is different every time, it's hard to match.
That's the issue you're facing by the way; when you switch simp reps or section cuts, the bounding box of what's on screen is changing, so the view updates.  (You're still looking at X% of the overall model, positioned at Y% from whatever edge was closest.)
Even text annotations on drawing views are affected by this problem.  Whenever I revise a drawing that has changed significantly, first step is always spending 10 minutes or so dragging text around back where it was to begin with.
I have been complain about this for years.  Only solution seems to be to use CAD software from another vendor.  PTC has shown no interest in fixing it.  I was told in 2013 that some of the problems would "probably" be fixed in Creo 5.  Wasn't.
Relevant cases I've opened with PTC support over the years (and related documents and SPRs):
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=10726384
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=11296143
    https://www.ptc.com/en/support/article?n=CS122986
    https://support.ptc.com/appserver/cs/view/spr.jsp?n=2830675
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=11811068
    https://www.ptc.com/en/support/article?n=CS157634
    https://support.ptc.com/appserver/cs/view/spr.jsp?n=2208433
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=12735565
    https://support.ptc.com/appserver/cs/view/spr.jsp?n=4803255
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=13487049
EDIT:  Actually though, you should add "refit_upon_section_activation no" to your config.pro; prevents the problem in one case anyway...
dcokin14-AlexandriteAnswer
MaCallan5-Regular MemberAuthor
Hey thanks for the reply!
Haven't fully digested it yet, but it's good to know there's someone out there.
"refit_upon_section_activation = no" sounds like it might solve a lot of this for me, but I don't find it in the config options. Was this added in Creo#4 or #5? (i'm still using #3).
And I see you've beaten the PTC bushes hard about this — god bless. I'm guessing there's no point in looking to PTC for any further guidance.
