How to keep the worker temp dir
Hi All,
We have PDMLink running on a Sun server and productview adapters on a separate windows server. On both the PDMLink server and the Windows server there are temp directorys created when publiching containing the published objects.
Does anyone know how to set it up to enable these temp directories to remain after publishing (either on the PDMLink server or preferably on the Windows server)?
The reason for asking is that I would like to use a scheduled task to look for PDF's and move them to a separate place and then the scheduled task will delete the temp folder.
I played arround quite a bit in the proe2pv.rcp without success.
Any ideas are highly appreciated.
Hans Berg
