Dec 15, 2016 11:53 AM UTC
HOW TO LINK VB WITH CREO-2
Hai All,
  I have a requirement of creating an CREO assembly file using VB.Can anyone suggest how to link creo and VB program and how to write a VB code.
With Regards
Aghil M
Dec 16, 2016 5:40 AM UTC
Hello Aghil,
  It may quite complicated if you try to VB Automation on Creo without VB Coding knowledge. But it is possible by your hardwork & time if you're ready to spend.
1. Go through this link to learn basics of VB Visual Basic Tutorial - visual basic learning center
2. To implement VB functionality in Creo you must installed VB API with Creo, see the below link for more information
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS141739&lang=en&source=snippet
3. Look for VB API folder in your Creo installed location, [Path may be look like this C:\PTC\Creo2-amd64-M120\Creo 2.0\Common Files\M120\vbapi]
That folder contains Documentaions & lot of example of VB Coding for CREO.
All the best
Hello Aghil,
All the best
Dec 16, 2016 6:28 AM UTC
Thanks for the guideline parthiban,
Dec 16, 2016 7:57 AM UTC
Hi Aghil,
you have the possibility to use Creo's VB API which is for free or I can recommend you Automation Gateway which has to be paid, but is easier for the development.
Tom
Dec 16, 2016 9:57 AM UTC
Hai Tomas.
Thanks for your reply, My requirement is kind of  i want to create an assembly file, for that the input is an excel sheet and a notepad file. we don't have to work on the part level. so from excel if i choose a particular set of input i should get the assembly file ready in creo. with some co-ordinate system and planes.
so what i want to know is is this possible with VB API or should i get a licence for Creo Toolkit.
As i am a beginner to this level. Please guide me how to link this excel and my creo.
Thanking You
Aghil M
Dec 16, 2016 1:55 PM UTC
VB API should be enough for this. Please read the VB API documentation...
