How to Map "Ctrl" Key to Another Key on CREO 7.0
I am trying to use the measure tool on CREO to measure distance between two points.
And for CREO 7.0 to measure the distance between two entities, "Ctrl + left click" is needed to measure the distance.
However, currently my software has some bug that I cannot use the Ctrl + left click. (I'm using CREO on my virtual box and Ctrl+left key on virtual box will not give the correct response)
Therefore, I will like to ask if I can map the Ctrl key to another key(any number or alphabet) on CREO 7.0. I have been trying to look for key map for the ctrl key but have no success so far.
Will appreciate for any feedback or suggestion, thanks in advance!
1st, I'd check your virtual box software settings for a clue as to why CTRL+Click is disabled.  Ctrl+(left)Click is essential for many interactions in Creo and in Windows in general.  Otherwise, using a keyboard remapping utility comes to mind...
AFAIK, the buttons are hard-coded in Creo, but usually, it is the control panel keyboard settings that will determine which is the "primary" and "secondary" button (typically left, and right buttons)
