How to Mirror a part with text/feature you want to alter
I am going to give two examples of my issue in hopes that someone has a suggestion. The second case is a little confusing.
1. Mirror a part with text
We often create a mirror part but we do not want to mirror the text for obvious reasons. The text on our parts are part of the casting. If you mirror a part with text, the text appears incorrect/mirrored on the other part. If we suppress the text before we mirror, we can add the text to the mirrored part, but if we resume the text of the original, it will show up on the mirror version. (We want them to be dependent)
2. Mirror a part with different feature
If we have a part that has a mirrored version but one specific feature is different. We want to create the mirror part but exclude that one feature. In order to keep the parts dependent, we created an instance of the original part and turned off/suppressed that feature on the instance. We then open the instance and create a mirror part from it. Now we can add the new feature to the mirrored version.
This works but the problem is that when you try to Save a Copy of this part, it all falls apart.
We open the original (Generic) part and Save a Copy to a new name. You must open the table and rename the instance but the mirrored part will continue to reference the original instance name which still exist but it's not in session. I tried opening the mirrored and Save a Copy to it's new name in hopes that when I have it in session and rename the instance on the new part created from the generic, that it would update the link between them but it does not work. The mirrored part and the Save a Copy of the mirrored part still links itself to the original instance name.
Any ideas on how to mirror a part that is dependent while excluding a single feature between them. We can't figure out a way to make this work. If we make the mirror process independent, it works but we loose the ability to make changes to one part and have it automatically update the other.
ΜΟΛΩΝ ΛΑΒΕ
