How to model sliding pivot
Trying to model a joint. I have a kicking leg part, that has a slot cut down the middle. The slot engages a fixed post, so that the leg can both slide up and down on the post, and rotate about it. We have not been able to correctly constrain the model to be able to animate it to demonstrate that the design is sound. I'd appreciate any help in figuring out what kind of constraints to use, and how to use them.
