How to move images between sheets in Creo 9.0 drawing?
I have few images in sheet 1, I want to move them to other sheets. I don't see how this can be done, please help me.
Emeritus
Hello @IS_9869112,
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry. You could add -
  1. What type of Image?
  2. Current Placement & where do you want to move it to?
  3. If you tried already, are you encountering any specific issues or error messages while attempting to move the image?
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Vivek N
Community Moderation Team
Hello Vivek,
Its a .png image which is already there in my drawing sheet 1, I want to move it to sheet 2.
I dont see an option to move the image from sheet to sheet. How to do it? I cant even copy the image or save the image from my drawing to my desktop.
There is an option "copy from other drawing" but copy from the same drawing or moving to other sheets, I don't see an option.
can you please guide me here?
Best Regards,
Syed
@IS_9869112 wrote:
Hello Vivek,
Best Regards,
Syed
if you use Images command then you're out of luck.
You have to use Object command. Unfortunately this method may not work.
Object command works well with .bmp files. To move a picture from Sheet 1 to Sheet 2 use CTRL+X and CTRL+V (Cut and Paste functionality).
kdirth
The easiest method may be to rearrange the sheet tabs (and rename) and move the views to the new first pages.
lol, moving the views is the challenge here. 😊
kdirth
Yeah, it is kind of hard to select all of the views in the drawing tree the select Move to Sheet and select the new sheet. 😉
