how to move items in an assembly to the footer
  • February 3, 2016
  • 1912 views
To all,
I am looking to see how to do two things.
  1. Create a footer in an assembly (if it is even an option)
  2. Move an item (part) to the footer
I tried to find it through the Command Search in Creo. When i typed in "footer" it says it is not in the ribbon, but is located in the Shortcut menu.
When i went to the Shortcut menu under the Options, I did not see it.
So if anyone can give some guidance on this it would be greatly appreciated.
Dennis
a cut and paste from the help center:
To Move Features to the Regeneration Footer
You can move the features that are created by default in the active list (in the Model Tree above the Insert Here node) to the Regeneration Footer. These features include the Analysis features, Publish Geometry features, Reference feature, Annotation features.
Note
An Interface Feature is created in the footer by default.
  1. Right-click the feature that you want to move. The shortcut menu appears.
  2. Click Move to footer.
You can move the feature types mentioned above from the active list to the Regeneration Footer or from the Regeneration Footer feature list back to the active list.
  2. Click Move from footer.
Note
By default, zones are created in the Regeneration Footer feature list. But, for legacy parts that were created in versions before Pro/ENGINEER Wildfire 2.0, you must use Move to footer to move the zones to the Regeneration Footer feature list.
You cannot move zones from the Regeneration Footer feature list to the active list.
Hopefully this is what you were looking for, unless you're playing in harnesses...
