ND_10940562
11-Garnet
How to pass the button from creo8 to creo 7
Hello everyone, how are you all doing?
I’d like to pass over some buttons (manual created) in Creo 8 to creo 7, but I haven’t been able to find any shortcuts associated with them in the configuration. I also tried replicating the same configuration and toolbar setup in Creo 7, but the buttons didn’t show up at all. I found a folder containing the button image and a .res file, but I’m unsure how to implement these in Creo 7.
What would you recommend I do?
Hi!
Mapkeys are stored in config.pro file (...\Common Files\text, working dir).
UI settings (Tabs, panels, buttons) in
creo_parametric_admin_customization.ui (...\Common Files\text)
or
creo_parametric_customization.ui (working dir, user folder)
ND_10940562
11-Garnet
actually ive tried it doesnt work, i wont even apear the button
Catalina
Community Manager
Hi @ND_10940562,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina | PTC Community Manager
