How to remove model restriction from a parameter
  • November 17, 2016
  • 0 replies
  • 1017 views
I have a CREO assembly model, provided by another company.  We are attempting to bring the model to our standards, which includes entering a string description into the "DESCRIPTION" parameter field.  Unfortunately, when I try to do this, I get an error stating Invalid Value.  The parameter itself shows String as the type, and our restricted parameter file indicates it should be string, but it will not let me enter text.  Updating the restricted parameter file does not help.  Also, deleting and recreating the parameter does not help (in fact, in recreating the parameter it tries to create the parameter as a Real Number type instead of String.  If I check the Conflict Report in the Parameter dialog box, it shows there is a conflict between the model restriction and our restricted parameter file.  How can I remove the model restriction from the assembly model so that we can correctly enter the proper information??
