MikeBennettAnswer
Hi
This is the answer and confirmed via Help Center - To Rename a Harness
You will need to do this from the assembly level. After confirming the new/keep name from the Assembly, the Assembly Rename window opens, allowing you to keep or rename the components within the assembly.
Mike
