ND_10940562
11-Garnet
i got - i think its mc enable interact or enalble, the box wasnt check.
Mahesh_Sharma
22-Sapphire I
Hi ​@ND_10940562
I think article https://www.ptc.com/en/support/article/CS360747 will help you.
Thanks.
18-Opal
There are a couple of options for this.
One of the simplest is to use NItro-BOM (it has both standard and batch options) to extract the parameters to Excel, make the changes, and then confirm operations were created, modified, deleted.  Nitro-BOM can be used for other purposes beyond this - but it is really good for this problem/usecase.
If you are looking to do more advanced workflows, you could also look at Nitro-CELL or even CREOSON if you wanted to program your workflow at a lower level.
Dave
