Jul 19, 2016 7:40 PM UTC
How to save explode views with file
I'm wondering if there is a way to save out assembly explosions with a file in Creo such that they may be re-opened after closing Creo or rebooting the computer. For example, if I open a step file of an assembly and create an explode view - is there then any way to save that step file and preserve that explosion? Or is there a specific file format that preserves explosions?
2-Explorer
Jul 20, 2016 11:05 AM UTC
Hello David Klein
it´s is possible to save explode views for later use. l think your explode view hasn´t been saved. Unsaved explode view is marked with "+" (same like Simplified representation)
See following picture:
If you need export exploded assembly try following:
- create desired explode view
- save explode view
- set desired explode view active
- choose FILE - SAVE AS - select type *.STP - confirm OK
- your explode assembly schould be exported (try to open *.STP file to check it)
Don´t know any config options related to this "topic".
Hope it helps...
Regards
Milan
