how to set default option while inserting / importing DXF ?
  • March 28, 2017
  • 4 replies
  • 1962 views
We want to set default option while importing/inserting DXF file in creo drawing. We want to set below options:
1. Import dimensions - as separate entities
2. Create variable sheet size
3. create multi-line text
and if DXF font not getting in creo then take isofont as default. so please someone can help me to do this setting
FYI. below snap shows required options.
Prashant Pandarkar
18-Opal
March 28, 2017
Hi Prashant,
When I import a DXF into a drawing, the Create Variable Size Sheet & Create Multi-line text options are already selected by default.  But I'm not sure if it is possible to specify the default option for Import Dimensions.
Amit
Hi Amit,
At my end only one option is got selected as default Create Variable size sheet, so have you done any setting to set as default for Create multi-line text and create variable size sheet.
Also I want to know currently whatever dxf not getting font it apply "font" as default so i want "isofint" instead of "font"
so please can you help.
Prashant
8-Gravel
April 12, 2017
Hi Prashant,
you can control the dialogue options with config entries as follows:
intf2d_in_dim AS_SEP_ENT --> imports dimensions as 2D elements, AS_IS would import "real" dimensions, AS_SYM would create a symbol out of every dimension
intf2d_in_create_multiline_note yes/no
intf_use_variable_size yes/no
There are lots more of other settings for this dialogue, just have a look at the configuration options:
BR,
Uwe
