Jul 29, 2012 9:20 PM UTC
How To: show model annotation of a "measure" feature.
I find using parameters and relations very cumbersome.
How do I annotate a value saved with a measure feature in a note?
A link to a tutorial about managing relations and/or parameters much appreciated.
...It still amazes me as to how hard it is to access saved dimension relations.
Aug 1, 2012 4:53 AM UTC
Hi
I believe you have saved some dimensions in part and want to show that in drawing note
If so then you need to
1.Save a measure analysis and create a feature from that saved dimension.
or you can directly create a feature from measure analysis.(I am not sure you follow which process; but in both ways you will find a feature)
2.create a parameter from that feature
3.use that parameter in note in drw
please check the video
But if you need something else ;please reply
Regards
K.Mahanta
Video Link : 3187
Hi
Regards
K.Mahanta
Video Link : 3187
Aug 1, 2012 8:02 AM UTC
Sweet! That is what I was missing. I was trying to use the "measure" directly in an annotation.
I have a lot to learn about making this work for me.
Thanks!
Aug 1, 2012 10:48 AM UTC
Hi
You can also use the measure feature directly in drawing annotation ; but need to be a little bit careful
Check the following video
Regards
K.Mahanta
Video Link : 3188
