How to show text for 2 or more parameters from a part family table in a simple repeat region cell?
Trying to show text from 3 parameters that are included in a part family table in a single cell that's part of a simple repeat region in a table on a family table part file drawing. How does reference a family table instance part parameter in a simple repeat region relation?
I have found examples of referencing assembly members but not part file instances.
Example of what I want the address cell to look like
How table currently looks
Example of repeat region relations not working
Appreciate any help you may provide,
Don A.
Creo 8 sample files attached
I modified your Table 1 and created Table 3, Table 4 (these are modified copies of Table 1).
Then I copied Table 1 to Table 5, Table 3 to Table 6, Table 4 to Table 7.
Finally I moved Table 5, Table 6, Table 7 so they overlap. A large zoom is required when moving the tables.
Modified data attached.
kdirth
"A large zoom is required when moving the tables"
I would suggest selecting each table and use Move Special
Select the top left corner and enter location values.
I had to Customize LMB menu and to add Move Special command into it.
