How to turn off hatching when converting dwg, dxf after creating a cross section in 2D drawing
Subject: How to turn off hatching when converting dwg, dxf after creating a cross section in 2D drawing
Body:
I am using Creo Parametric - Release 5.0 (connected) Release 5.0 and Datecode5.0.3.0
Hello.
After creating a cross section with a 2D drawing, if there is a way to avoid hatching when converting dwg or dxf.
Thank you.
Translated with Google Translate by Emily on May. 18th, 2022.
Subject:  2D 도면으로 횡단면 생성 후 dwg, dxf 변환 할 때 해칭 안나오게하는 방법
안녕하세요.
2D 도면으로 횡단면 생성 후
dwg, dxf 변환 할 때 해칭 안나오게하는 방법이 있는지 확인부탁 드립니다.
감사합니다.
select hatching and use Erase Cross Hatching command.
