I have a assembly which is checked in. When I try to modify it I end up having a conflict box asking me to check out or continue
Hello all,
I have a assembly which is checked in. When I try to modify it I end up having a conflict box asking me to check out or continue. I want to avoid this conflict box avoiding and set default value as continue. I used dm_checkout_on_the_fly and set it to continue but noticed it just the continue is set just in conflict box as default but did not get applied I have to select okay eveytime. Is there any option by which I can apply value as continue instead of setting default value in conflict box.
TIA
StephenW
Test using the config option:
dm_auto_conflict_resolution yes
This a hidden option so you can have to add the option manually.
I would suggest you do a some testing on this option before you do heavy work. Hidden options are useful but they are not supported by tech support and sometimes have unexpected issues.
