I want to disable automatic sketch zooming
Does anyone know of an option that controls the auto zooming in sketch mode. Example: editing dimensions while inside a sketch, if I zoom in to see what I am doing, it zooms back out to the full view after every dimension edit.
I found the answer to this question in an old post referring to WF 4 (config option of refit sketcher to no), but where is this option in Creo?
Patriot_1776
"sketcher_refit_after_dim_modify" set to: "no"
I found this in the PDF of the config options, that are attached. It should work for you. I have mine set and like it 90% of the time, but then I've chosen not to use creo and am using WF4.
Patriot_1776
I found it, thanks!
Thanks guys for both asking and answering!
-Art
