[Idea] "Virtual Clear Coat": automatic surface fairing to improve continuity (G3/G4) within a controlled tolerance
SUMMARY
In real production, paint, clear coat and polishing physically level small surface irregularities: the final glossy surface looks smoother than the underlying sheet metal. I propose a Creo function that mimics this process virtually: an automatic fairing tool that improves surface continuity up to G3/G4, within a maximum deviation chosen by the user, like the thickness of a coating.
Similar fairing tools exist in dedicated Class-A software (e.g. ICEM Surf). The idea is to bring this capability into Creo, integrated with Boundary Blends and the parametric model.
THE PROBLEM
- Reaching high-quality continuity (G3/G4) across a surface network means hours of manual work: adjusting control points patch by patch and checking reflections.
- Most surface networks built in a parametric CAD reach G2 at best, with small curvature irregularities that are visible in reflections on glossy parts.
- In reality the coating "fixes" what the model doesn't, but the design model itself stays imperfect.
THE IDEA: HOW IT WOULD WORK
1. Select a surface network (a group of Boundary Blends or style surfaces).
2. Set the maximum allowed deviation from the original shape (for example 0.05 mm, comparable to a coating thickness).
3. Set the target continuity at patch boundaries: G2, G3 or G4.
4. Creo runs a fairing optimization: it slightly moves the control points to minimize curvature variation across the patches, while respecting the boundary continuity targets and never exceeding the maximum deviation.
5. Where the surface degree is not high enough for G3/G4, Creo can raise it automatically or warn the user.
Conceptually it works like the real coating: virtually "adding and removing material" within a thin layer, until the surface is mathematically smooth.
VERIFICATION
- Reflection (zebra) analysis before / after, side by side.
- Curvature comb and curvature map before / after.
- Deviation map showing how much each area moved, always within the chosen tolerance.
- The original surfaces are kept, so the result can be compared or rolled back.
BENEFITS
- Class-A-like reflection quality without hours of manual control-point editing.
- Measurable and controlled: the shape never moves more than the set tolerance.
- Closer link between the digital model and the real finished product.
- Useful for automotive, motorcycle, consumer products and any glossy visible surface.
Thank you for considering this idea. Feedback and votes are very welcome.
