8-Gravel
IFX Fastener Error
I've created a custom screw in IFX and all works great except I get 1 error when placing the screw. When I select the hole, head and nut reference and click OK to place screw, I get an error saying......
What does this mean? I'm new at customizing IFX and can't figure this issue out.
Below is a portion of my .dat file.
!Socket Head Cap Screw
!McMASTER-CARR
SCREWTYPE	01
UNIT	INCH
SURFACE	392
AXIS	427
SYMBOL	STRING	DN	LG	S	DK	K	SH_HEX_DEPTH	SUPPLIER_NAME	SUPPLIER_NUMBER
INSTANCE	STRING	DN	LG	S	DK	K	SH_HEX_DEPTH	SUPPLIER_NAME	SUPPLIER_NUMBER
SHCS_0-80-x-0_064	#0-80	0.060	0.064	0.050	0.096	0.060	0.025	McMASTER-CARR	92196A047
SHCS_0-80-x-0_094	#0-80	0.060	0.094	0.050	0.096	0.060	0.025	McMASTER-CARR	92196A051
SHCS_0-80-x-0_125	#0-80	0.060	0.125	0.050	0.096	0.060	0.025	McMASTER-CARR	92196A052
SHCS_0-80-x-0_156	#0-80	0.060	0.156	0.050	0.096	0.060	0.025	McMASTER-CARR	92196A053
SHCS_0-80-x-0_188	#0-80	0.060	0.188	0.050	0.096	0.060	0.025	McMASTER-CARR	92196A054
SHCS_0-80-x-0_250	#0-80	0.060	0.250	0.050	0.096	0.060	0.025	McMASTER-CARR	92196A055
SHCS_0-80-x-0_281	#0-80	0.060	0.281	0.050	0.096	0.060	0.025	McMASTER-CARR	92196A416
What is the "INSTANCE row for? The template .dat has it in there and I was wondering if I even need that?
OliverGräbner
it seems like that the fastener has some unresolved relations in the .prt file.
Please make sure that the param_relations.txt create a correct relation set inside your fastener with the given parameters.
See also: Relation Files (ptc.com)
Oliver Gräbner - B&W Software GmbH
OliverGräbner
