8-Gravel
IFX is it possible to disable the automatic hole creation
IFX in Creo 10.0.4.0
When using IFX it standard creates holes in modifiable parts. When you don't want that you have to set it manually each time to "Do not create a hole".
Is it possible to have it default always set to "Do not create a hole"  for all parts?
OliverGräbner
you can change the IFX-option HOLE_VISIBILITY in General Configuration Options
If set to 'NO—Do not create a hole.' no holes are created any more.
Oliver Gräbner - B&W Software GmbH
OliverGräbner
Hans_B8-GravelAuthor
8-Gravel
A little late but: thank you!
OliverGräbner
Hi @Hans_B ,
what do you mean with a little late?
I have anserd on you post in November.
