IFX - Screw and hole diameter
Hi everyone,
since I need to get screws based on threaded holes, is there any chance to set screw diameter by thread surface diameter or to set DG dimension on drilled hole surface?
Community Moderator
Hi @PB_10368600
 Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
