3-Newcomer
Jul 27, 2026 1:43 AM UTC
IFX标准件如何直接从PLM中调用
I am using Creo Parametric Release 11.0 and Datecode11.0.0.0 IFX紧固件选择后,是否可以直接从PLM中调取模型直接进行装配,而不是本地每次参数化生成,导致无法与PLM中的标准件库匹配
Emeritus
Aug 5, 2026 12:32 PM UTC
Hi ​@QL_9633327,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Community Moderation Team.
OliverGräbner
Sep 22, 2026 7:54 AM UTC
Could you solve your problem in the meantime?
If a fastener is uploaded to windchill it will be reused.
It is necessary to upload the fastener once.
Oliver Gräbner - B&W Software GmbH
